I'm using the global variable ga to control things here.
Bit 0 is the Accept/Ignore bit which is toggled by the Pacer CC68 v127 in translator 0.1
When za bit 0 is 1, it is "listening for a message from CC8 (translator 0.0)
In translator 0.0 if we are not listing as indicated by za bit 0 then we don't do anything. However if we are listening we set message pending bit 1.
Transator 0.1 looks for message pending bit 1 (if we are still listening) and once you hit CC68 V127 on your pacer will complete the outgoing message of CC68 V127 and reset the pending message flag (bit 1)
Translator 0.0 is only looking for messages from Ableton Port Alias
Translator 0.1 is only looking for message from Pacer Port Alias.
I hope this helps!
I neglected to define an output port in the project file so you will need to do that at the project level before it will work. There are “Log” messages that I use for debugging which are only available in 1.8.5 (beta) or later. In 1.8.4 they will be treated as labels and simply ignored.
Yes, since we have 32 bits in a global variable (such as za) we could use 2 bits for each combination and have a total of 16 combinations with a single variable.
I chose za because I don't think it was used in your project file but if I'm wrong, we could change it to something else. Did you test it? Also, it was unclear whether you wanted CC8 v1 to go through or not when you weren't listening for it. Right now CC8 V1 never gets passed through but if you want that we could add some logic in translator 0.0.
