Thank you Steve! Finally It’s resolved!!! 🙂
Trying to configure the BCR2000 by software (B-Control / BC Manager) was quite a challange. Because via the software, was not possible for me to save a preset or save a modified version of the standard preset in the BCR2000. B-Control froze after trying to save a change directly in the hardware, via the B-control Software after an Error Message popped up. And BC Manger was able to load/recieve the BCR2000 settings and sent them back to the hardware, after they were changed to my taste, but the hardware kept jumping back to it’s original state (if someone knows a solution, my controller seems to be looked for changes via an external software). Maybe after sending back the new prest you have to push the \"Store\" Button on the device two times to finally safe the changes? With BC Manager alone I was not able to get the preset into the device permanently (Maybe I did something wrong? I cant figure out what exactly.)
The only real thing, the only way that worked, was the direct modification on / in the hardware itself, by using the hardware buttons, like it is written in the BCR2000 user manual, on page 15! Many thanks Steve for that Idea!!! 🙂
You do the following (directly on the BCR2000 / from the internal preset bank I choose preset No 1 for the modfication):
- press and hold the “EDIT” button and at the same time
- turn the knob that you want the settings to be changed, then release both again (the button and the knob), in the display you see now the number of the knob, now
- turn the”MODE” knob in the upper knob-row until you see “rel 1” displayed
- press the “EDIT” button again to exit the edit menue, then
- press the “STORE” button once, now it blinks
- press the “STORE” button again, now the change is saved forever in the machine
Now when you turn the knob it only delivers a value of 0 or 127 , nothing else in between, although variable other values are shown in the display!
Than you go to the bome software and assing the relevant knobs for the CaptureOne tools. I use the loupedeck custom keystroke settings, because they covered all the sliders very well, so you dont have to do it yourself. Install loupedeck software (even without actual hardware possible), than change inside CaptureOne the shortcut/keystroke preset to the \"loupedeck beta\".
- Select your relevant midi controler from the list, after pressing the midi symbol in the upper right corner
- press “Add Translator” in the middle window and give it a plausible name
- check the “Capture MIDI” Box in the right “Incoming” window
- turn the knob into the wanted direction, to the right for increase the value (it shows 1), to the left for decreasing it (it shows 127)
- click on last shown incoming midi-message-line (or) your preferred value
- jump directly to the “Outgoing” tab and choose “Key Stroke”
- click in the blank fiel und type the key stroke for the needed tool (for example for the CaptureOne Color Balance Tool “Shadows – HUE increase”: Strg (Cmd)+Alt+Shift+1)
- follow step 4. to 7. again for the opposite direction
Your done! As simple as that.
If you want to reset the default factory settings of the BCR2000, download the preset-pack from the Behringer Homepage (here for the BCR2000):
Settings -> “Factory Settings” and put them into the BCR2000 with the bome “Send SX” software. All your previous settings inside the BCR2000 memory will be overwritten / deleted (as far as I know).
This is how it worked for me. If someone finds something that is wrong or incorrect or knows a better/ improved way, or has something else to add, please feel free and welcomed! 🙂
Many thanks again Steve for that excellent help, advice and support!!!
