Hi Mike,
Send this message to your MKII when you start the project. This alters the behavior of the APC40 by putting it in Mode 2 instead of Mode 0.
In Mode 0, the buttons and knobs behave as you indicated. The buttons 1-8 will indeed latch and send knob values of the knobs on the right.
In Mode 2, all buttons are momentary instead of latch and the knob values on the right will not be sent.
Also in Mode 2, there is no local control of LED or knob rings. We handle that with sending feedback to the controller with MT Pro. The last project file I sent you (APC-40-Knob-Memory.bmtp) should show this behavior.
In that project file under the preset Init, there is a translator called “Set PPC40 to Mode 2” (it might be mis labled as Mode 1).
It sends the following to your APC-40 at project start to put it in Mode 2.
F0 47 7f 29 60 00 04 42 09 07 01 f7
The 42 above is for mode 2. For mode 1 it would be 41 and for the default mode (Mode 0), it will be 40.
You want it to be in Mode 2 so that you have full control of the LED’s and rings (and CC values) with MT Pro.
Note, in Mode 2 the values of the knobs at the right do not change channels. If you want to do this, you will have to set up something similar as I did with the top knobs (first two channels in the example I sent you).
P.S. I also set it so that you can press the ESC key on your computer keyboard (without MT Pro being the focus) and it will re-initialize (via the Init timer). The timer also triggers and project opened.
