You might need to change the definition of the "Special" Key from Alt to something else in order to achieve what you want. The "Special Key" is used for a number of MIDIBuddy special functions.
The special key can be changed in the MIDIBuddy System Tray Settings menu.
Ok. I keep the special key selected to ‘none’. That won’t be an issue.
(If the Alt key wasn’t usable, I would never be able to use FL Studio at all)
The question, is I’m struggling to somehow imitate holding the Alt key down. I imagine this is more difficult with the MB formula in there. So my idea is to have the first translator ‘hold Alt down for 200 ms’ and then have the rest of the translators after that one, as normal. When 200ms is up, it will just let go of the Alt key without having to have any ‘stop’ command, that might interfere with the mouse return formula. ?
I don’t see a ‘hold key down’ option in the keystrokes. ?
First of all, I'm not sure what MIDIBuddy will do if you select nothing. Better to select something other than Alt.
As far as key down. There is an option in keystroke output for down only and up only. Just make sure you eventually send an up with a different translator after you send a down.
