Hi! I am having problems with the keys in my Arturia Beatstep, y setup de key play a video with space bar. Sometimes works and sometimes don’t work. Any clue?
Hi, the application needs to have focus? Does it? Are you on Windows or Mac?
What is the application your are sending space bar to?
Another thought is maybe you have incoming note-on at set velocity. Make it “Any” velocity set to qq since the Arturia pads are velocity sensitive.
Adobe Premiere!
Well it could be a problem with Premiere. See this post.
If not, if you are using MT Classic, you might need to set your Arturia Beatstep to send fixed velocity notes.
