Bome Box as Wireless Transmitter
I am trying to connect a midi controller to bome box and over wifi, connect to my computer/BMT and send the signal out USB to control another hardware keyboard.
Can bome box be used this way and if so, how? I can't seem to figure out how to see signal in BMT, AL even though BOME BOX-NET is connected!
Help!
So you have MIDI USB Controller -> BomeBox -> Bome Network ->Computer -> hardware Keyboard? If so, yes this should be possible.  You need tomake sure you have a MIDI route on your BomeBox to your Computer using Bome Network. Then on your Computer have MT Pro routing from your BomeBox to your external keyboard.
I assume your computer and BomeBox are on the same WiFi network and both as a client. Either that or set you BomeBox up as a WiFi HotSpot and connect to your BomBox from your computer that way.
