I have the BomeBox and also BMTP - is there a way I can use my wifi network to connect my iPad to the BomeBox? Does this require Bome Net Pro running on a connected computer to bridge between iPad and BomeBox?
It’ll work by installing Bome Network on the iPad, then you can directly connect from the iPad to the BomeBox (either via existing WiFi network, or from a WiFi network opened by the BomeBox).
