After installing and unlocking Bome Network Pro on my iMac and my MacBook I am still not being given the option to connect them when I go to Connect To. They are not recognizing each other even though they are on the same wireless network and physically less that 2 ft apart. Please advise.
Hi, just another thought: I assume you’re using a WiFi router? Some routers have a setting “guest isolation” or similar. It is a security feature that prevents different devices connected to that router to communicate with each other. Maybe you can find such an option in the WiFi router’s configuration? Which WiFi router model do you use?
Best regards,
