Hi Herbert,
we’ve taken your input to bump up priority on the feature request for adding Unlimited Named MIDI Ports to MIDI Translator Pro directly.
Hi Herbert,
Hey Florian, that would be awesome. Have spent many many hours setting this up that would have taken just a few minutes if that feature had been available. So totally would welcome this new feature.
And Steve, thank you so much for patience and help. Looks like I got it working now, taken quite a bit of time but hopefully this will continue to work and be more stable than loopMidi (which is wonderful donationware but some issues have popped up).
Thank you both!
Thanks, we cannot promise anything, but it would be great to have it in MT Pro directly.
Good to hear you got it working now. To be extra sure, you can create backup copies of the Bome Network settings, see here:
Bome Software Settings Files
Hi, if you are running on Windows PC, I have an AutoHotKey script I can share with you that can help you save and recall different routing scenes (route set).
You may need to make a few tweaks to it for operation on your PC. I did this primarily because I often switch scene routing configurations when working with different users and I can always easily recall my last working scene.
Here is what the dialog box shows for selecting or saving presets.
That’s very interesting, will note that. I try to set things up once to then forget about it but that’s good to know that exists because that might change my workflow. Will think about that, thanks for the heads up
