Hi
All Pionner devices send NoteOff commands as regular NoteOn with velocity=0.
I appreciate that this is invalid MIDI, but it is quite simpler as then there is only "Note" messages.
https://github.com/pestrela/music_scripts/blob/master/ddj/1%20MIDI%20codes/DDJ-1000RB%20-%20MIDI%20Messages.pdf
On Bome, the NoteOFF trigger already makes the exception to trigger on these NoteOn+vel=0 messages.
However the NoteOn trigger ignores them.
Could we further relax this to the NoteOn+vel=0 trigger as well?
thanks
PS1: On the output side this is not a problem. I always send NoteOn+vel=0 messages using a variable.
PS2: This would prevent massive duplication of my code since I cannot use "timer-zeros" as well:
https://www.bome.com/support/kb/can-timer-zero-events-be-injected-before-any-already-buffered-messages
