I need to send ribbon(CC16) to Pitch bend
Ribbon have 0 to 127 and when is released come to 64
Any help ? Thanks
Any help ? Thanks
Does the ribbon controller send any other MIDI message when it is released or are we going to need to use a timer to determine that? The timer would monitor changes in the CC and if no changes withing x ms set it back to mid point.
after release ,he send to computer value 64 on MIDI Channel 1,2,3
Hi, please find the attached. There are 3 translators
If you controller actually sets it back to center after ribbon release, you will only need the first translator.
Brilliant !! You are my hero !!
Glad to help!
