Hello! I own an Ampete 88S-Studio which is an amp and cabinet switcher and an RJM Rack Gizmo Amp and FX/Function controller. The Ampete has external Ethernet I/O for performing any amp/cab switching and the Rack Gizmo has rear Midi I/O ports and a front 6 pin port to attach a foot controller. I would like to know if your Bome Box will allow for bi-directional talk between my two devices?
Hi, in looking at the manual, it appears the 88S does not have MIDI connectivity and has network connectivity only. My guess is the network protocol is proprietary and not support by the Bome Network Protocol.
However it appears that the 88R has both MIDI and network connectivity so you would probably need this device and use MIDI to connect between your Rack Gizmo and the 88S. I would assume the 88S and 88R would support the same network protocol and although BomeBox would not utilize it for MIDI, its standard router functionality would work. So I think this configuration may work for you.
