# Correct String for Setting LED in APC 40 MK2
**URL:** <https://forum.bome.com/t/correct-string-for-setting-led-in-apc-40-mk2/940>\
**Category:** Bome Products\
**Created:** [June 17, 2018, 2:09pm UTC](https://forum.bome.com/t/correct-string-for-setting-led-in-apc-40-mk2/940 "2018-06-17T14:09:43Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Author:** ![s.claussen](https://forum.bome.com/letter_avatar_proxy/v4/letter/s/77aa72/32.png) [@s.claussen](https://forum.bome.com/u/s.claussen)\
**Post date:** [June 17, 2018, 2:09pm UTC](https://forum.bome.com/t/correct-string-for-setting-led-in-apc-40-mk2/940/1 "2018-06-17T14:09:43Z")
</div>
Hey there,
i try to set a colour status fpr my led on APC 40 Mk2.
When i take a look at the Communication Diagram is written down that:
Format of Type 1 outbound Midi note-on messages
Byte Number
Value
Description
1
0x9\<chan\>
MIDI Note-on. The 4-bit \<chan\> value will be used for the track strips
2
\<ControlID \>
Identifier for LED object (“note number”)
3
State
Control value (This value will describe the state or color of the LED: OFF/ON/blinking, etc.)
Assignment of Note number messages to LEDs. Note 0x30 to 0x39 use MIDI Channel 0 to 7 to indicate Tracks 1-8. All other note values ignore the MIDI Channel.
Version 1.2 – January 19, 2015 Page 13
Note Number
MIDI Channel
Corresponding LED
Velocity
0x00
0-15 = RGB Type
Clip Launch 1
See “RGB LEDS” Table below
0x01
0-15 = RGB Type
Clip Launch 2
Akai APC40 Mk2 Communication Protocol
MIDI Channel
Corresponding LED
Velocity
0-15 = RGB Type
Clip Launch 3
0-15 = RGB Type
Clip Launch 4
0-15 = RGB Type
Clip Launch 5
0-15 = RGB Type
Clip Launch 6
0-15 = RGB Type
Clip Launch 7
0-15 = RGB Type
Clip Launch 8
0-15 = RGB Type
Clip Launch 9
0-15 = RGB Type
Clip Launch 10
0-15 = RGB Type
Clip Launch 11
0-15 = RGB Type
Clip Launch 12
0-15 = RGB Type
Clip Launch 13
0-15 = RGB Type
Clip Launch 14
0-15 = RGB Type
Clip Launch 15
0-15 = RGB Type
Clip Launch 16
0-15 = RGB Type
Clip Launch 17
0-15 = RGB Type
Clip Launch 18
0-15 = RGB Type
Clip Launch 19
0-15 = RGB Type
Clip Launch 20
0-15 = RGB Type
Clip Launch 21
0-15 = RGB Type
Clip Launch 22
0-15 = RGB Type
Clip Launch 23
0-15 = RGB Type
Clip Launch 24
0-15 = RGB Type
Clip Launch 25
Note Number
0x02 0x03 0x04 0x05 0x06 0x07 0x08 0x09 0x0A 0x0B 0x0C 0x0D 0x0E 0x0F 0x10 0x11 0x12 0x13 0x14 0x15 0x16 0x17 0x18
Page 14
Note Number
MIDI Channel
Corresponding LED
Velocity
0x19
0-15 = RGB Type
Clip Launch 26
0x1A
0-15 = RGB Type
Clip Launch 27
0x1B
0-15 = RGB Type
Clip Launch 28
0x1C
0-15 = RGB Type
Clip Launch 29
0x1D
0-15 = RGB Type
Clip Launch 30
0x1E
0-15 = RGB Type
Clip Launch 31
0x1F
0-15 = RGB Type
Clip Launch 32
0x20
0-15 = RGB Type
Clip Launch 33
0x21
0-15 = RGB Type
Clip Launch 34
0x22
0-15 = RGB Type
Clip Launch 35
0x23
0-15 = RGB Type
Clip Launch 36
0x24
0-15 = RGB Type
Clip Launch 37
0x25
0-15 = RGB Type
Clip Launch 38
0x26
0-15 = RGB Type
Clip Launch 39
0x27
0-15 = RGB Type
Clip Launch 40
RGB LEDs Type
RGB LEDs
MIDI Channel
Function
0
Primary Color
1
Secondary Color – Oneshot 1/24
2
Secondary Color – Oneshot 1/16
3
Secondary Color – Oneshot 1/8
4
Secondary Color – Oneshot 1/4
5
6
Secondary Color – Pulsing 1/24
7
Secondary Color – Pulsing 1/16
8
Secondary Color – Pulsing 1/8
9
Secondary Color – Pulsing 1/4
10
11
Secondary Color – Blinking 1/24
12
Secondary Color – Blinking 1/16
13
Secondary Color – Blinking 1/8
14
Secondary Color – Blinking 1/4
15
Name
Color
Velocity
60
#000000
0
59
#1E1E1E
1
58
#7F7F7F
2
57
#FFFFFF
3
1
#FF4C4C
4
2
#FF0000
5
3
#590000
6
4
#190000
7
5
#FFBD6C
8
6
#FF5400
9
so the Synthax i Try to speak to the LED is as follows
1.Midi Note On= 09
2.NoteNumber e.g.= 01 (ClipLanch 01)
3.State= 01(Secondary Color – Oneshot 1/24)
4.Color= 57 ( color) 01 (Velocity)
so my string is
09 01 01 57 01
this is what i write in outgoing / Midi Mesage / Raw Midi Message exclusive
but it doesnt work ... maybe you can help me , i try to search the whole google but dont find a paper where i can see the correct string to set the led by outgoing message.
thank and best regards
Basti
**Author:** ![SteveC](https://forum.bome.com/user_avatar/forum.bome.com/stevec/32/8250_2.png) [@SteveC](https://forum.bome.com/u/SteveC)\
**Post date:** [June 17, 2018, 3:50pm UTC](https://forum.bome.com/t/correct-string-for-setting-led-in-apc-40-mk2/940/2 "2018-06-17T15:50:45Z")
</div>
Hi Note on message for MIDI Channel 1 note 1 would be in hex 90 01 xx. Where xx is the velocity (color) you want.
For the first byte, 9n is the Note on Message where the “n” is the MIDI channel-1 in hex (0-F)
The second byte is the note number 00-7F in hex (0-127 decimal)
The third byte is the color value from the table you indicated.
In MT Pro you can either send it as raw MIDI:
90 01 05
Or select
Note On Channel 1 Note 1 value 5
Let me know if this helps get you on your way.
[bome@sniz.biz](mailto:bome@sniz.biz)
&nbsp;
**Post date:** [June 19, 2018, 2:48am UTC](https://forum.bome.com/t/correct-string-for-setting-led-in-apc-40-mk2/940/3 "2018-06-19T02:48:42Z")
</div>
Hey Steve ,
thanks for your very fast reply.
That works now and i understand a bit more whats going on there .
There are a bit more Questions i have:
Why can i not OR how can edit several Translators at one time ?
When i try to select 10 Rows and than set e.g. “outgoing” to “none” only the first row except the command
other 9 are not except the change
I can Export a Preset to an txt document so i can edit the txt with notepad ++ and change e.g. all values 7F to 15
but how can i import the edited version of preset in the bome ??
The last Question i have is ,i have a init preset to set all led to red which look like this:
90 00 07 90 01 07 90 02 07 90 03 07 90 04 07 90 05 07 90 06 07 90 07 07 90 08 07 90 09 07 90 10 07 90 11 07 90 12 07 90 13 07 90 14 07 90 15 07 90 16 07 90 17 07 90 18 07 90 19 07 90 20 07 90 21 07 90 22 07 90 23 07 90 24 07 90 25 07 90 26 07 90 27 07 90 1A 07 90 1B 07 90 1C 07 90 1D 07 90 1E 07 90 1F 07 90 0A 07 90 0B 07 90 0C 07 90 0D 07 90 0E 07 90 0F 07
this is a bad view to edit it in the Raw Midi Cell , is there a way to make it much better looking and better editable with the rules ?? or does that not work ?
Sorry for the foolish question i try to google all the themes before but its very hard to find something.
Thanks and best Regards
Basti
**Post date:** [June 19, 2018, 3:52am UTC](https://forum.bome.com/t/correct-string-for-setting-led-in-apc-40-mk2/940/4 "2018-06-19T03:52:28Z")
</div>
See comments below:
Hey Steve ,
SJC\> Unfortunately bulk editing of translators is not possible at this time.
SJC\> Sorry bulk editing of translators is not currently possible.
SJC\> Great questions but there is no import feature. The project file is somewhat editable in a text editor but you have to be careful as the rules don’t always have line feeds and have other “magic” type of data. What I do with some success is to save a backup of the existing .bmtp project file, then edit the new copy in a general purpose text editor. Then save it being careful not to mess up any of the “magic” stuff (which is why I make a backup). Then re-open the newly edited file the Bome MIDI Translator Pro. It’s not perfect but it works in many cases.
SJC\> Another great question. There are a few approaches that I use.
1. If I want it all in a single translator, I create a spreadsheet to create what I want and use the spreadsheet auto increment feature. I then export to a text file and copy and paste it into the raw MIDI cell.
2. If you don’t mind more than one translator, you can create an incoming event that fires on project open that triggers a timer a number of times. The timer can then iterate through the output numbers that you want so essentially it is doing all the work for you. Here is what it might look like if you have 64 sequential notes going from 0 to 63 with velocity of 0.
Incoming : Project Open
Rules: ga=64
Outgoing : Timer “Iterate” ga times
Incoming : Timer “Iterate”
pp=64-ga
ga=ga-1
&nbsp;
Outgoing: Raw MIDI : 90 pp 00
&nbsp;
So essentially you would get 90 00 00 , 90 00 01, … 90 3F 00
SJC\> None of these are foolish questions. I’m happy to help!
&nbsp;
Basti
