I am just evaluating Midi Translator Classic for my personal use.
I need to distribute PC incoming on one channel from a port and send them, maybe after modifying the PC number, to 2 output ports.
I wrote a translator using one output, but it seem that I can’t select another output, all translators use the only output we select in the list which does not seem to be a multiselect list ?
It looks like a limitation of this version, even if I pay for it ?
Could this be done with the Pro version ?
I fear that the pro version is very complex related to the simple task I need to do.
You will need MT Pro for this. You can test the functionality via the trial version if you would like. The only limitation is it will time out every 20 minutes. Once you have determined it works OK, then you can decide whether to buy it.
I can help you set it up this simple functionality if you would like.
Let me know.
Thanks for support, I finally got the Pro version and will use it next week.
If any problem I will come back to you, but I don’t think it will be necessary.
