I use Davinci Resolve, Icon Platform B + and BMTpro
I experience that Resolve on the first stroke can decode eg. Num 2 but on the next stroke it is decoded as 2
I use:
In:
Midi message-RawMIDI
Out:
outgoing-key stroke-physical-num2
Is there a code in BMTpro that can tell Resolve that this is always eg.Num 2?
In most cases, this is caused by the application not keeping up with the speed in which MT Pro sends keystrokes. Have you tried creating a 20ms delay between keystrokes?
What platform and version are you using with Bome MIDI Translator Pro?
No, it is still only on the first stroke, then Resolve seemed to freeze, after saving Resolve will accept some keystroke frome BMTpro but not eg.Num2 or any thing that’s included Shit, Conrol ,Option or Command
I believe that it is an Resolve problem but is there a workaround…?
What version of Bome MIDI Translator Pro are you running? Since you mentioned “Option” I assume you are on a Mac? I will try to duplicate your issue if you are on Build 1.9.0 build 1022. If you are not on that build please download and install it. I believer there may have been some keystroke issues on Mac for earlier builds.
