Does BomeBox support two BOSS KATANA-100/212 connections and midi over usb to both of them?
I’m currently using a laptop with Bome MIDI Translator Pro installed and it works perfectly with two BOSS KATANA-100/212 and midi over usb, but I would really like to use the BomeBox instead as it will fit on my pedalboard perfectly.
I’m not sure if this device is USB MIDI class compliant. If you had to install any special drivers on you laptop, it might not be class compliant. If you use the standard windows drivers then you should be OK.
You might also reach out to Boss to see if tese are MIDI USB class compliant as BomeBox should support this. Of course you would need to use a USB hub on the BomeBox and I would always recommend a powered USB hub just to be safe.
