Using trial version of MT Pro and every note works on both my MIDI keyboards except for E4.
Here’s the entry in the Log Window: 27: IN 0.0 Note On on ch. 1 with note:64 (0x40) and any velocity=83
How can I get this one note to work like all the others?
Maybe you should look for any velocity instead of velocity 83. Every time you hit the key, it may be a different velocity and it might be hard to always hit 83. Some keyboards send fixed velocity so my guess is they would be 127.
If that doesn’t work, try posting your project file and I can look into it further.
This keyboard doesn’t have fixed velocity and still every note is working except for E4. Attaching the project file. Thank you for your help.
Project: NATE - Embers and Pianoteq
Project MIDI IN ports: E-MU XMidi1X1 Tab, nanoKEY2
Project MIDI OUT ports: Embers, Pianoteq
Route #1: IN ‘E-MU XMidi1X1 Tab’ → OUT ‘Embers’
Route #2: IN ‘E-MU XMidi1X1 Tab’ → OUT ‘Pianoteq’
Route #3: IN ‘nanoKEY2’ → OUT ‘Pianoteq’
Route #4: IN ‘nanoKEY2’ → OUT ‘Embers’
[x] Preset 0: NATE
[x] Translator 0.0: Nate
Options: swallow
Incoming: Note On on ch. 1 with note:64 (0x40) and any velocity
Outgoing: (none)
I seem to have figured it out. Somehow I created an Incoming action in the Translator that said to do nothing when playing E4. Not sure how I had created that!
