I'd like MT to accept any key I press on my laptop and then use rules to determine which key it was and respond correspondingly.... otherwise I'd need a translator for each key.
Is there a way to do this?
Gabriel
Gabriel
Hi Gabriel,
For keyboard input from any key you will need to either:
Maybe I should add this feature to MIDIBuddy, where MIDI buddy would take a key stroke and send MIDI note to MIDI buddy based on its Virtual Key code? The think I would need to be concerned about if I did this is to make sure the keystrokes used don’t interfere with any of MIDIBuddy’s current hotkeys.
I attached a file that has keyboard input mappings for QWERTY keyboard.
Thanks Steve,
Figured you’d have the answer. your point about interfering with MIDIBuddy hotkeys made me realize that I’d have a bad time avoiding Live hotkeys as well. I think my best path is to free up some pads on one of my Akai APC MINI’s and use them instead of the Qwerty keys. I have to give up some functionality I wasn’t using much anyway, so I think this is the most direct path forward.
In your debt, as always…
Gabriel
OK, Gabriel, yes if you could free up some controller keys, that would probably be cleaner.
