I would like to know how to set a LaunchPad mini's pad to be solidly lit, on the activation of a preset. I understand that Bome MT's routing needs to return to the LaunchPad and I know the colour numbers. I am trying to set up multiple presets, each one with different pads lit. I don't require the pads to change colour or switch off.
Hi, I believe there are multiple versions of the LaunchPad MINI. The latest is RGB. Which one are you looking at? I believe the programming of the MK1 and MK2 are the same but am not sure. I believe mine is MK1.
