Try removing your MIDI Thru routes. Swallow only works if the following conditions are true
1 - The outgoing message executes
or
2 - The outgoing message executes and the outgoing action is NONE
So a rule like this will NOT swallow since the outgoing message does not
execute. What will happen is that all channels will still go the MIDI thru route
// Check for MIDI CH 1 in local variable oo
if oo!=0 then exit rules, skip outgoing action
Outgoing : Note on channel 1 value qq
However this WILL swallow the messages
// All channels except MIDI channel 1 will be swallowed
if oo==0 then exit rules skip outgoing action
Outgoing: NONE
I hope this helps! Consequently, I generally do not use MIDI Thru routes unless I want to pass through SysEX. If so, you need to put one more more translators in place with outgoing action of none to suppress anything that you don’t want to pass thru.
