The names are the real ones + a Bome word as prefix in the alias. And in the M3 i removed the SOUND word from the alias\’s name.
I do have it functionning except for the Program Change part.
Oh, i just noticed that there are 2 translators with the default ones in scene 2 part, but i did’nt work on them yet.
Do you see the Program changes going out looking at the log?
No
I found a workaround for the Program Changes using the release of the switch pedal to send the Program Change.
That is, as the scene/song selection is sent on de pressing of the pedal as 127 value and as such the selection becomes made, the depressing of the pedal, as Value 0, will send the CC# (as Any CC, Any Value, from the Teensy Pedal port).
So, i put:
Incoming:
From Port: Teensy Pedal
Any CC#
Any Value
Outgoing
Bank Change#
To Port: Bome PC3K
It is working now. ;)
Now: Transpose and find a way to have feed back to know which Scene/song is active
Thank You Steve
Probably just need to set up another preset that directs output to your controller and send note-on or note-off to control the LED. Usually (but not always) MIDI controllers accept the same note number for turning on and of the LED. Velocity of the note controls the color if the controller LED’s are multi-color. If not multi-color it is usually velocity 127 for on and 0 for off.
