mapping akai apc 40 mk2
OK Tommy,
I disabled the translator that covered LED feedback for all 40 Matrix buttons.
I added another translator for just 2 buttons and showed examples of toggling just the two.
I used global variable ga for button 1 and gb for button 2. The preset is set up just to accept input and feedback to your APC40MK2.
For any other button you will need to create a new global variable. Each button must have its own global variable in this methodology. I did not use bit mapping since it seemed to confuse you which is why I disabled the other preset.
1549896635916_akai-apc-mk2-2019-02-11.bmtp
hello Steve
found a way for the 40 buttons–
they only work as a flash button..but at least they work..
[x] Translator 1.26: BUTTON 1 ON
Options: swallow
Incoming: MIDI 90 00 7F
Outgoing: Note On on ch. 1 with note:87 (0x57) and velocity:127 (0x7F)
[x] Translator 1.27: BUTTON 2 OFF
Options: swallow
Incoming: MIDI 80 08 00
Outgoing: Note Off on ch. 1 with note:88 (0x58) and velocity:127 (0x7F)
I would like a push button on,push again off
but for the moment it’s ok
thank u anyway
best
Tommy
Try this for button 1
Options: swallow
Rules: ga=ga^1
Outgoing: Note On on ch. 1 with note:87 (0x57) and velocity:ga
Are you sure you have a MKII?
hello steve
thanks will try in that way..
here’s a pic of what I have..
![](upload://6afLPslZeSY1q0ATyApGh0HJlVj.jpeg)
Hm interesting. and which button are you calling button 1?
I assume you are trying to control PAN LED. The solution I originally gave was for the 40 matrix clip launch LED’s.
hi
ok now everything work..
in flash mode works as toggle but it’s ok
here’s the number of the buttons
![](upload://bZBz1DhzgUXcMuu9BVNNjNHV6Jb.jpeg)
