Hi, I am trying to run MBT Pro on my Mac Mini 2012. I've installed it by dragging it to the Applications folder and then running it. As far as I know I entered the license user name and key correctly, but once I click the OK button for MBT to restart it just gives me the busy message. Any suggestions?
Not sure, I think I double clicked instead of dragged it. Could you give that a try?
(I\'m also using Catalina and Bome MIDI Translator Version 1.8.4 with a MacBook Pro)
