Pushing a button on my Novation Zero SL MKII is causing multiple translators to trigger.
So I found out that each button is sending four different messages from one button press. It sends the assigned NRPN message, but also three other CC messages that I didn't assign. Each button sends these three CC messages, as well as their own respective assignment. It's always CC #'s 9, 98, and 99. This is bizarre. I've reinstalled the driver, and tried all the firmware settings, but nothing seems to fix it. I'm waiting for a response from Novation. Does anyone know why this would happen?
You know what, I had no idea about that. Thought NRPN was simply a different type of message.
I will head over to that site and do some study.
The issue is, CC#6 is conflicting with something else. It’s strange, because I don’t have CC#6 on anything that I can find. But when disabling a certain knob, the problem disappears.
I wonder if I should just stick with basic CC assignments instead of NRPN. How many is there in total for a channel, 99?
Hi, since NRPNs use two 7 bit numbers the total possible number of NRPNs used could be up to 16384. My guess is your controller uses much less. As far as CC#6 not showing as being used. Some DAWs have only show CC#6 that are manually mapped by the users and use scripts or some other means to internally map functionality.
NRPN (stands for Non Registered Parameter Number) since the are non-registered, are freely useable by a manufacturer of anything they want. So best to steer away from CC numbers that are associated with NRPN's in your programming.
CC 98, 99 6 and 38.
Ya I just discovered CC#6 was the offender. Every button was executing their translator, but also moving the knob that was assigned to CC#6. I moved the assignment and it seems to be working now, thank you again.
