Midi Translator 6 , 7 and 8 virtual in ports are closed when project is open.
Just started happening. If I open them and save the project, when it is opened again they are closed. Any fix?
Hi, you might want to check if any other MIDI application is running. This is the most common cause of this problem. Check also for possible background applications that might use MIDI ports. In my case, I had installed CopperLAN which insists on taking complete control of all MIDI ports. Once I disabled it, all was well again.
See if rebooting your system helps.
Good Luck!
Bome Q&A moderator
