hi,
ive been using Bomes for a little while now and have mapped separate mouse & keyboard presses
i need some help with how to do a mouse click then follow up with a keypress…
its probably a simple solution but i havent figured this one out.
would appreciate any help with example script to carry this simple 2part process… or however many parts i wish to implement if at all possible
The first translator handles the incoming action and starts a timer. Each step (translator in a timer) has a different outgoing action. The delay between actions is added on each step. In this case, 100ms is added between each step.
