I have my midi CC #30 velocity 127...translated to an outgoing"ctrlz" keystroke. The program recognizes the midi but refuses to output outgoing message. Ive recently switched to pro and this did not give me issues before hand.
Hi, if you could post your project file that would help.
With that said, open the log window and check MIDI IN, Incoming and Outgoing.
If you see MIDI IN but not incoming, it means there is something wrong eith the trigger event in the translator. If you see Outgoing Cntl(Z) Message Suppressed , take the focus off of MT Pro and try again. Unless set otherwise in settings outgoing messages will only be sent if MT Pro is not the focused application.
