Is it possible to combine an incoming cc to mouse+shortcut combined message?
I need to send a right click first, then down down down down enter.
Hi, for sending a sequence of events, you would have multiple translators with the same incoming trigger and a different outgoing action. Each outgoing action would be delayed differently to align with the outgoing sequence of event you want. If you are turning a knob, you might need to set a global variable to ignore
after the initial knob movement.
For instance
incoming = CC 1 on MIDI CH 1 any value
if ga==1 then exit rules, skip outgoing action
ga=1
Then in the last translator a rule to set ga back to 0 to re-enable the knob input after the sequence is complete.
Great! Thank you.
