I have been using Bome Midi Translator Pro to control Capture One via keyboard shortcuts. In the new version of Capture One (21) there is a great feature called quick edit which allows adjustments by using the mouse wheel while holding down keys on the keyboard. Is it possible to program a physical key + mouse wheel movement in the software? It seems that I can only choose the mouse or a physical key combination, not both…
Hi and welcome to the Bome Community!
Yes, please find the attached.
I have 4 translators:
- The first on triggers on an incoming note and the outgoing is a 1 shot time. I use the timer so that if I want to change the incoming note, I only have to do it in one translator.
- The second translator sends a key down for Shift
- The third translator scrolls the mouse up 20 after a 20 ms delay
- The last translator releases the shift key after 40 ms delay.
Hold-Key-Mouse-Wheel Combo-2021-03-02.bmtp (1.2 KB)
