Is there a shortcut to check and uncheck presets and translators so i dont have to use the mouse?
I’m not sure on Mac but on Windows, if you have your cursor in the preset window, you can use up and down arrows to select a given preset and then space bar to toggle enable/disable for the preset you currently have selected.
Thanks Steve that worked!
You’re welcome, Preston!
