Sorry for the new topic, but I was looking to map a timed single keystroke in Bome. I’m trying to map the navigation tools in Cinema 4D, but in the software the hotkeys are press and hold only (press and hold key “3” and mouse drag for orbit).
Is there a way to map a single timed keystroke to perform this task? I’m wondering if a timed on then off rule might work. An example would be great if you have the time, thanks guys.
I’m still a bit confused in what you want. Are you talking about MIDI note in to hold down a computer keystroke for a period of time. Or the other way around.
The translators in preset 0 handle the first case.
The translators in preset 0 handle the second.
Great thanks for the help! This site has been really informative. I’m going to map PS brush size on a fader if possible now. I might try fader up to increase size (keystroke [) and fader down to decrease (keystroke ]).
Bome interprets the fader with several codes as it listens, so I might have to read the forums on this topic.
You might want to look at this tutorial. Except instead of a relative encoder output, if the change is positive send one key stroke and if the change is negative send the other. I remember putting a distinct example of this situation on the forum so you could search there too. If you can’t find it let me know.
