That was probably it: it works!
Thank you so much for your help
You are welcome! Glad to see it is working for you!
Hello Steve,
a quick check on the unblocking translator: did I set the unblocking note specifically to note 17 in the following example?
and could I also achieve this by checking the “note” box in the following screen instead of the "any note " box and filling in 17?
If you want a specific note on only one octave then remove the line that says
pp=pp%12
However since we bitmap the notes into a global variable only the first 32 notes (note 0-31) would work.
You could hard code the note number into the input trigger and then put
ga=0
as the only rule to clear the bitmap. If you do this I suggest you
- duplicate the translator
- uncheck the original translator
- Edit the new translator
That way if you ever want to go back you can uncheck the new translator and check the old one.
