Hi
I have recently purchased the Bomebox. I have constant trouble selecting or changing Projects.
Every time I select a project on the "Midi Translator Project" of the browser, it is highlighted in green, so far so good.
But when I change to the "midi ports" page, it says "current project [no project]".
Eventually, every project I select will load properly and allow me to select midi ports.
But this usually involves selecting the project, waiting 5 minutes or so then powering the Bomebox off then on again. Sometimes I have to do this several times.
When I get a yellow dialogue box telling me I need to select midi ports or certain midi devices need to be plugged in, that is usually a good sign that the project has been properly selected. Then when I go to the "midi ports" the project is selected. But sometimes those yellow dialogue boxes disappear as I am trying to configure midi ports and the "current project [no project]" returns in the top left of the screen.
I have tried using the USB power supply I got with my 1010 music Blackbox. It is 2.5 amps. Otherwise I am using powered USB hubs of at least 2 amps. The Bomebox is not powering down, it doesn't seem to be an obvious power issue.
Once a project has been successfully selected, it usually loads when I power up the Bomebox, without having to use the computer to select it again.
However recently, even once I have successfully got a project working by messing about on the Web browser, no project is selected after I power the Bomebox off then on again.
The projects I am making are around 500 to 700 kb. Is there a limit on the size of project that can be reliably selected on the Bomebox?
Is there something specific I have to do to make a project load automatically when I power up the Bomebox?
