WIFI client with static IP
Hi!
Is it possible to set a static ip when in WIFI client mode?
There is no DHCP server on our network. And no ethernet cable connections.
All help apreciated!
Best Regards,
Jan
Yes, this can be done in advanced setting but is generally not reommended.
In WiFi normal setting set it up as a Hotspot.
Then go to advanced settings and then iterface and select wifi.
You can change the IP address and then check “Disable DHCP for this interface”
Thanks for your fast anser!
Why is it not recomended?
Freundlicje gruesse,
Jan
Jan Sjöberg
Hi&Ho Music
jan@hihomusic.com
Mobil:
+46705809152
Besöksadress:
Lodgatan 14
21124 MALMÖ
Postadress:
Mäster Eriksplan 12H
21158 MALMÖ
www.hihomusic.com
We never recommend setting anything in advanced options as unless you really know what you are doing, you can mess things up. There is less (or no) protection in messing up a configuration in the advanced options screen, where the setting in the primary options are pretty much bullet proof. With that said, you can still lock yourself out if you do something wrong but that is what the network recovery procedure can fix.
Ok, thanks!
Jan Sjöberg
Hi&Ho Music
jan@hihomusic.com
Mobil:
+46705809152
Besöksadress:
Lodgatan 14
21124 MALMÖ
Postadress:
21158 MALMÖ
www.hihomusic.com
