It appears by looking a your project file, page 1 and page 2 should move you faders, however the rest of the faders will not jump to their last known position on that page. Only the fader you are moving with GMA2. Page 3 will not work since your preset does not have your controller as the output port. Is this the behavior you are seeing? Did you see my email response regarding paid services?
Yes correct. For example when i Change Page from Page1 to Page2, all faders was still on Page1 position. I need to tap each of the Faders from GMA2 to recall the value/position of each faders. What i need to happen is when I change each pages, faders should automaticall move/follow with its assigned value/position.
Steve, do you have other email?.. Its 3rd time you sent mail but i dont receive anyone of them. I just checked my SPAM folder still NONE. Send me an email with your alternative email address. Let see if i can receive it now.
Hey, Iām getting my mail bounced back but didnāt notice until now. Could you send me another email from an alternate email address that you have and I will try and respond again.
Hey Iām using the same files however when I bring the fader up Bome sends a note after itās up that brings the fader back down to the start. Any idea? Bome: IN: X-Touch ext OUT: BOME MIDI 1 MA2: IN BOME 1, OUT: X-TOUCH
Hey I'm using the same files however when I bring the fader up Bome sends a note after it's up that brings the fader back down to the start. Any idea? Bome: IN: X-Touch ext OUT: BOME MIDI 1 MA2: IN BOME 1, OUT: X-TOUCH
Yes, GrandMA does not echo back anything you send it. If you put a static route in the MIDI router section from your X-touch back to itself, it should work fine. Mackie faders always require remote feedback to make them stick in their new positions.
Hello, I made a similar project with MA to control the faders with the x-touch. I wanted to ask you how you made the database so that when you change the page in MA, the faders take the value of the selected page. thanks
Assuming you have figured out how to get fader feedback from GrandMA (there is no automated way that I know of without scripting), you monitor all pages at all times from MA2 and put the values into global variables.
Then you set up MA2 some mechanism via MIDI to send to MT Pro that you just switched pages.
In MT Pro, when the page switch is detected via a MIDI message, you use a repeating timer to update your X-touch with the values of the global variable you used for that particular page.
For something like this I usually change presets and have a different preset per page. The MIDI message invokes a preset change and I have each preset use an incoming trigger āon preset activeā trigger the repeating timer that actually sends the global variable values to the controller for the given preset.
Then the active preset also monitors the global variable to update them in real time as long as it is selected.
I hope this helps!
hello steve thank you very much for your answer I am beginning to understand how to do it. Would you have some example project to observe well. Thank you
Hi, I found a way to get fader feedback using MIDI Show Control on GrandMA. It will work with any faders that have an executor defined as a fader type.
In GMA2 go to SetUp and then MIDI Show Control
My MSC setting look like the below
In options set up your MIDI Device
Setup whatever Faders you want as Mstr
Now GMA2 will recognized any active faders by the page number and fader number.
I set up one preset for page 1 faders in the following MT Pro file.
Set you aliases accordingly in the MIDI Menu
There are two translators. One that translates XTouch MCU faders to MSC for GrandMA2 and the other for MIDI Feedback that translators MSC back to MCU to the XTouch.
Make sure your X-touch is in Mackie MCU mode.
I hope this helps!
This works brilliantly with a Presonus Faderport 8 in MCU mode, but I canāt get it to switch banks, so I can only control the first 8 GMA faders. Would I have to read the Next Bank button to set a variable to jump to a new set of Translators?
And, of course, thereās nothing in the scribble strips. Thereād be no way to tell what bank I was on.
Yes, you would probably need to add a global variable to determine what bank you are on and increment it on bank up and decrement it on bank down. Then you would use the bank number to recalculate the outgoing value you want to send to GMA2.
You could also use the global variable to determine the messages you want to send back to the scribble strips. It would likely need to be handled locally by Bome MIDI Translator Pro unless you wrote a LUA script in GMA2 to send the required SysEX message back to your controller.
Thinking about it, Iād lose the feedback to the motors, unless I somehow saved and restored every setting. Sigh. The Faderport 16 should just work for one entire bank, though. Get the rest on the touchscreen.
OK, finally getting back to this one. As is, your translator addresses Executers 1-8. I want to address executers 16-24. Capturing MIDI Executer 16 seems to send 0F where Executer 1 sends 00. Youāre putting that in the variable oo.
I canāt figure out what the oo=oo|224 does, or how to modify it.
