56V PoE Injector?
I’m using a Black Box LPJ001A-T-R2 PoE Injector to power my BomeBox. Working great so far (after bizarre issues cause by a $12 PoE injector from Amazon). However, the specs are:
AC input voltage: 100–240 VAC, 50–60 Hz; 0.8 A;
Output: 56 V, 0.536 A;
Pin 3, 6: +56 V;
Pin 1, 2: Return
So it’s putting out 56v rather than the (?standard?) 48v.
Is that OK?
I’ll wait for Florian on the official answer. Meanwhile I found this post.
The BomeBox works with PoE power up to 57V.
