7bit Midi NRPN messages to midi CC problem
hi, im trying to convert NRPN messages to midi CC from a sequential prophet x
but im really struggling with it. not sure how to go about it.
ive been down this road before with a novation a while ago and didnt get too far with it
but hopefully this will fare better
ive inlcuded the manual, the midi details are on page 78
if anyone can help it would really get me started, thanks Chris
Prophet-X-Users-Guide-1.3.pdf (6.5 MB)
See the below example. Translator 1.0 does it by a raw input message and Translator 1.1 does the same thing using NRPN 7 bit incoming message.
You can use either method but I suggest you select only one of them.
In this example, I convert incoming NRPN master course tune on MIDI CH1 to CC7 on MIDI channel 1 passing the value of qq as shown on page 147 (PDF Page 81)
You will need to set up aliases for your devices. I have them set up as follows.
You can learn more about aliases from [this tutorial](https://youtu.be/CrE391VJL0s).
7bit NRPN to CC Example.bmtp (2.4 KB)
I hope this helps
thanks for this, i cant get this to work though
is it possible you can set it up to do the cutoff filter as an example
as the master tune is in a hidden panel, thanks for the help
It looks like you want ENV Filter amount which is just CC47. I don’t see an NRPN parameter for this.
Hi Steve
the prophet x works in x2 modes CC and NRPN.
The midi CC mode has very few controls available, but NRPN has pretty much everything available.
on page 148 and 149 of the manual env filter amount is available on NRPN layer A (202) and NRPN layer B (2250) with a range from 0-254.
The synth has two layers and shares the same knobs but the knobs control each layer.
i need to use the NRPN tables because LFO control for example is only available as NRPN its not available as a CC.
Hope that helps explain what i mean.
Thanks again
Chris
OK, however a value of greater than 127 would require a 14 bit NRPN so the example below allows up to 7 bits which which is what a standard cc allows.
To figure the NRPN number MSB and USB you can convert 202 to hex which gives you a value of 0xca or 11001010 binary. The high bit needs to go into the MSB (01) and the remaining bits into LSB (74 or 0x4a).
Let me know if this works for you. If you need to convert 14 bit NRPN to 7 bit CC then you would need to use 14 bit NRPN and then scaling but of course you would not get the same precision.
7bit NRPN to CC Example-2026-10-25.bmtp (3.1 KB)
