I’m looking to create Midi Clips in Ableton Live to send to one particular plugin H-Verb
The only parameter I need is decay time
Unfortunately I can’t use the snapshot feature in SuperRack as I have utilized this for Waves Tune which
Selects the 12 major or minor keys from Ableton clips
This is done via IAC driver and MTP via the BMT1 virtual port
The goal is to set up various midi clips such as 2 seconds, 2.1 seconds, 2.2 seconds and so on
This would simply be added to a live set as a midi clip
Most likely be sent via IAC to SuperRack to then control that one parameter
Well this looks less like a Bome thing and more like an Ableton Live thing.
You should be able to create another IAC port and set up an automation lane in Ableton for the parameter you want to use and send that parameter to the H-Verb plugin as part of the clip. The output of the track would be the appropriate IAC port and the input plugin should be set to the same IAC port.
This might be a more appropriate question for either Ableton or Waves Forum. If you want to translate something between Ableton Live and Waves, then you could send to MT Pro and I could help you with the translation.
I would think that you could do a MIDI learn with the CC of your choice with MT Pro and then in automation tie the automation to the same CC. I’m not that familiar how Ableton Live assigns CC’s to automation tracks.
