Hey everyone,
greetings from Germany, nice joining y’all!
I am using Bomebox to remote foot control my new stage video and lighting setup.
I am sending MIDI program changes from my guitar FX (BOSS GT-1000) to
- The Lightshark LS-1. Here program change needs to be transformed into MIDI note signal. MIDI Translator and BomeBox do the job!
- Qlab to trigger Video (has a MIDI capture function and works just fine, without tranforming the signal.
related questions:
Can I also send the (via the DIN IN Port in the Bomebox) incoming data (with or without transformation) through the Bomebox USB A port to my Computer USB A Input to QLAB? I could not manage to make it do this. This should be possible, right? The USB port is not only in the Bomebox to receive Data, for instance from am USB Drive, like MIDI Translator files, correct?
Does the Bomebox USB Host to Mac USB Port not work, because I am using the MIDI Translator pro .bmtp file?
Where do I make the connection at first? Ii do not need MDID translator, right? Do I do it in the BOME Network App or in the Browser in the BOME WiFi…? Confusing.
Or does this all not work and do I thus need to go through a MIDI through Box I order to split the signal BEFORE going into the BomeBox?
If I could just get into the Bomebox, translate the signal before hitting the DIN out and not translating it before hitting USB… any tips on hox to manage this I would appreciate!
Thank you so very much, dealing with this!
best
Cris
