Akai apc40 Mk2 - Bank Switching
Is there anybody here who have managed to program the 40 clips to bank 1-8 ?
Is it even possible?
I have tried different things all day, but I just can´t figure it out.
Do I need to put it in ‘dumb mode’? Is that really someting you can do? If so… how?
Im gonna use it to control lights with mydmx.
I’m not quite sure what you are asking. Do you want the 40 matrix buttons to send different MIDI messages depending on the select switch you are setting below? This can be done but I’m not 100% sure what behavior you are looking for.
The APC 40 MK2 matrix buttons always send the same Momentary note-on messages when pressed and note-off messages when released. We can change the behavior through Bome MIDI Translator Pro but I need to understand exactly what you are looking for.
