AKAI LPD8 MKII LED Control from MIDI feedback
Hi all,
I"m very new to MIDI and I"m trying to work out whether it"s possible to get MIDI feedback working from Rekordbox to an Akai LPD8 MKII so that the pad colours/states reflect software state (specifically Rekordbox stem states).
What I"m trying to achieve:
  • Use the LPD8 MKII pads to control Rekordbox stem functions (vocal/drums/instrumental stems etc.)
  • Have Rekordbox MIDI OUT feedback change the colours/states of the pads depending on whether the stem is active or inactive
  • Ideally have the pad colours controlled by Rekordbox/software state, not by the controller"s own internal toggle behaviour
What I"ve done so far:
  • Using Bome MIDI Translator Pro
  • Using LoopMIDI virtual ports
  • I can successfully map the pads in Rekordbox
  • I can see MIDI IN messages from the LPD8 MKII in Bome
Example messages from a pad press:
  • Press: 90 28 7F
  • Release: 80 28 00
From my basic understanding, I think this means:
  • Note 40
  • Channel 1
  • Velocity 127 on press
  • Velocity 0 on release
The main issue:
I cannot seem to get the LPD8 MKII LEDs to respond to external MIDI messages at all.
I"ve tried:
  • Sending Note On messages back to the controller via Bome
  • Matching the exact same note/channel/value the controller itself transmits
  • Trying different channels
  • Different velocities
  • Momentary vs Toggle modes
  • Full Level ON
  • Pressure messages OFF
But the pads always seem to behave according to the Akai configuration software only:
  • static idle colour
  • separate “pressed” colour
  • no visible response to external MIDI feedback
I can"t even get a very basic test working where:
  • pressing one pad triggers Bome to change the colour/state of another pad.
This makes me think either:
  1. the LPD8 MKII does not support standard MIDI note-based LED feedback the same way the original LPD8 apparently did
  2. it requires SysEx or some other protocol
  3. there is some “external LED control” mode I"m missing entirely
I found an older Bome project on this forum for the original LPD8 which was suggested to control LEDs successfully, but I suspect the MKII behaves differently.
At this point I"m mostly just trying to understand:
  • whether this is actually possible on the MKII
  • and if so, what kind of MIDI messages the MKII expects for LED colour/state control.
Any guidance would be hugely appreciated because I feel like I"m missing one key concept here.
My guess is that the LPD8 MKII is programmed for toggle for the pads. You might want to download the LPD8 MKII editor and set the pads to momentary. Also, loopMIDI would not be required. You could use Bome Virtual Ports to communicate with RekordBox. I’m not sure if RekordBox sends MIDI feedback but I think it does.
You could try this template. It was made for DDJ-XP2 but has cross routing to allow MIDI message through.
I suggest you rename the aliases to a much more meaningful name.
For translator routing and device selection you might want to review how this works.
Also if you are on Windows11, the last I heard was that loopMIDI was broken (unless they fixed it recently).
