Yes it can do this but in order to do any translations, you also need to buy Bome MIDI Translator Pro. Then you develop what you need on Windows or Mac and then upload to BomeBox for final execution.
Hi, the following should work as long as you only have one note-on at a given time. The MIDI channel will change at every note-off message.
I use the global variable ‘ga’ for them MIDI channel, toggling it between 0 (MIDI CH 1) and 1 (MIDI CH 2).
We capture the value of ga into the local variable oo and send output to that MIDI Channel.
After capturing note-off we toggle the MIDI channel for the next iteration.
If you want to handle more than 1 note at a time, then the project will need to be modified to determine which channel we need to send the note-off messages or send them to multiple channels. If sending to multiple channels we change the outgoing action of translator 0.1 to make it a raw MIDI message with a note-off on both channels.
Here is how I set up my aliases for testing. You will need to set them up to point to the physical ports that you use.
