An impressive MIDI processing on Dexibell Classice L4
Hello,
An impressive video from the new Dexibell L4 , there isa 16:49 min long video and MIDI processing is shown on 1:28.
Can Bome Translator route only the highest and the lowest held note to a separate channels while leaving the other held notes unchanged?
Best regards, Marko
I didn’t see the video but yes, you can direct highest note and lowest note to different channels.
You have to have a bit of time to evaluate the notes as you may not press them at the exact same time. Also if the note is currently sounding as not the highest or lowest note and then you release a note that makes it the highest or lowest, you would have to turn off the note on the current channel and then send a note-on on the new channel. Also if it is sounding as the highest or lowest note, you would have to turn off the note and on again at the desired default channel.
Can you tell me what you are trying to accomplish here?
I would need to know the triggers when the notes sound and how they should interact with eachother in various scenarios. Also how many notes you would need to evaluate.
You may find some highest/.owest note examples on our forum by searching.
Hi. I want to accomplish what is demonstrated in 1:28 on the video from the link that can not be posted here. Best regards, Marko
You should be able to post a link now.
It looks like he is doing a simple keyboard split where there are two ranges of keys that are assigned to a given MIDI channel.
I don’t see what you described with a single high and low note.
Hi, in the video slice from 1:54 to 2:08, the timpani sound is triggered only by the lowest held note and the highest held note plays the trumpet . Marko
It doesn’t looks like it. It just looks like a simple split keyboard setup.
If you want a single note, I would need to know where the evaluation would made when you are pressing multiple notes maybe at different times.
Hi. Is trumpet here mono or poly? Are chords here made of trumpet chords or just the organ sound? Marko
No idea. If you want me to help you, you need to provide the necessary requirements and not just say make it sound like this video.
You can indeed make individual notes on different channels but when to sound and release the note on a given channel is important as well as what to do with the note when it was on a different channel and becomes the highest/lowest note or vis versa.
Here is a highest note example that I found with a simple forum search. Again you can search on the forum in you need more examples. I can provide examples as well but for free support, we do not provide full solutions.
If the trumpets play polyphonic, than the video is not as impressive as I thought. Thank you for your time, Steve.
