Hi, English please on this board. Here is your original question through google translate
Hey, I need help. How often is the LED feedback. How do I make it that my button in color 1 is lit when it is “activated” and in color 2 when it is “deactivated”.
So press green 1 times, press yellow twice
The velocities for the respective colors are known to me, but I do not implement it. Perhaps has a NEN tip
It is the Akai APC Mini
I found this on the APC40 which may be similar to the APC mini, but you should probably check the manual to see if there are any differences.
http://forum.djtechtools.com/showthread.php?t=38782
APC40 Midi Mapping Documentation and Resource
Hope this will help. I will be creating a Youtube walkthrough series on how to map different type of LED adn Rings.
Type of LED Functions.
0=off,
1=green,
2=green blink,
3=red,
4=red blink,
5=yellow,
6=yellow blink,
7-127=green,
Type of LED Ring Functions
0=off,
1=Single,
2=Volume Style,
3=Pan Style,
4-127=Single
Ring LED Just add + 8 to the current CC#.
Independent Bome Programming Specialist and Bome Q&A moderator
