I’m trying to build a MIDI setup, but stuff doesn’t work as I thought it would and I’m starting to hit my head hard on the wall.
My setup:
Controller: APC40 mk2 (USB-B out)
Computer: MacBook running Bome MIDI Translator Pro + Resolume
External device: Sleepy Circuits Hypno 1 (USB-A MIDI host only)
What I want to do:
Use one APC40 to control:
Resolume on my Mac (normal, via Bome/IAC)
Hypno at the same time, but with modified MIDI (different channel/note mapping done in Bome
Basically, I want to push a button that will select a preset on the Hypno and engage a clip in Resolume at the same time.
The problem:
Hypno can only accept MIDI from USB-MIDI devices, because it is a USB host. It also requires CC messages on the channel 16. APC40 doesn’t allow alternative MIDI mapping and sends signals on many different channels.
My Mac is also a USB host, so Hypno doesn’t show up as a MIDI output device in Bome.
Hypno’s manual confirms it only accepts MIDI from class-compliant USB MIDI devices.
What’s the simplest hardware chain that would let Bome send its translated MIDI stream into Hypno as if it were coming from a USB-MIDI device? Or any other way to make this setup work? Thanks)
