Hi I am trying to run this apple script as a translator output but it will not work… i get errors… runs fine in terminal
networksetup -setairportpower airport on
Any suggestions?
Errors are -2741: expected end of line but found identifiers
Any suggestions?
Could you post your script?
It may be how Bome uses the single or double quotes vs how Apple Mac expects them or some other character set issue. I think I’ve run into this before and that was the issue that fixed it.
Did you get this sorted out?
I did sort of. Ended up running a siri workflow triggered by bome that did what I wanted.
