Apple scripts seem to not work now and only generate an error in the console log. I killed prefs and reinstalled and still same problem. I thought maybe my session file was corrupted so I started from scratch and still having the same issue. The scripts I am using work in Apple Script editor and OSCulator so I know they are good. These all worked fine and never had an issue with BOME until this week. No upgrades had been done from the time it was working till it started failing.
Now using 1 virtual MIDI ports.2606 - Discovered MIDI INPUT : Bome MIDI Translator 1 Virtual In,IAC Driver IAC BUS,Network
2606 - Discovered MIDI OUTPUT: Bome MIDI Translator 1 Virtual Out,IAC Driver IAC BUS,Network,QLab
2606 - MIDIManager started.
2817 - Loaded Project file: /Users/greglandon/Documents/Bome MIDI Translator/Presets/MASTER.bmtp
2818 - Activated preset: CURRENT SHOW
9164 - IN 0.2 Physical Keys: Fn(Option(G))
9166 - OUT 0.2 ERROR executing Apple Script: action_0_2(): error -1708: (null)
11814 - IN 0.2 Physical Keys: Fn(Option(G))
11814 - OUT 0.2 ERROR executing Apple Script: action_0_2(): error -1708: (null)
13552 - IN 0.1 Physical Keys: Fn(Option(/))
13552 - OUT 0.1 ERROR executing Apple Script: action_0_1(): error -1708: (null)
14829 - IN 0.1 Physical Keys: Fn(Option(/))
14829 - OUT 0.1 ERROR executing Apple Script: action_0_1(): error -1708: (null)
18121 - IN 0.7 Physical Keys: Fn(Option(.))
18121 - OUT 0.7 ERROR executing Apple Script: action_0_7(): error -1708: (null)
18724 - IN 0.7 Physical Keys: Fn(Option(.))
18724 - OUT 0.7 ERROR executing Apple Script: action_0_7(): error -1708: (null)
18972 - IN 0.7 Physical Keys: Fn(Option(.))
18972 - OUT 0.7 ERROR executing Apple Script: action_0_7(): error -1708: (null)
19343 - IN 0.7 Physical Keys: Fn(Option(.))
19343 - OUT 0.7 ERROR executing Apple Script: action_0_7(): error -1708: (null)
20198 - IN 0.5 Physical Keys: Fn(Option(D))
20198 - OUT 0.5 ERROR executing Apple Script: action_0_5(): error -1708: (null)
33762 - OUT 0.7 ERROR executing Apple Script: action_0_7(): error -1708: (null)
36144 - OUT 0.7 ERROR executing Apple Script: action_0_7(): error -1708: (null)
39346 - IN 0.6 Physical Keys: Fn(Option(F))
39346 - OUT 0.6 ERROR executing Apple Script: action_0_6(): error -1708: (null)
39591 - IN 0.6 Physical Keys: Fn(Option(F))
39591 - OUT 0.6 ERROR executing Apple Script: action_0_6(): error -1708: (null)
39830 - IN 0.5 Physical Keys: Fn(Option(D))
39830 - OUT 0.5 ERROR executing Apple Script: action_0_5(): error -1708: (null)
40367 - IN 0.3 Physical Keys: Fn(Option(H))
40367 - OUT 0.3 ERROR executing Apple Script: action_0_3(): error -1708: (null)
40479 - IN 0.4 Physical Keys: Fn(Option(A))
40479 - OUT 0.4 ERROR executing Apple Script: action_0_4(): error -1708: (null)
41629 - IN 0.2 Physical Keys: Fn(Option(G))
41629 - OUT 0.2 ERROR executing Apple Script: action_0_2(): error -1708: (null)
42980 - IN 0.1 Physical Keys: Fn(Option(/))
42980 - OUT 0.1 ERROR executing Apple Script: action_0_1(): error -1708: (null)
43730 - IN 0.0 Physical Keys: Fn(Option(B))
43730 - OUT 0.0 ERROR executing Apple Script: action_0_0(): error -1708: (null)
