Hi, sorry for the delay. I’m having similar errors and checking into it.
tell application "Terminal"
activate
my execCmd("ls")
end tell
on execCmd(cmd)
tell application "System Events"
tell application process "Terminal"
set frontmost to true
keystroke cmd
keystroke return
end tell
end tell
end execCmd
Bome MIDI Translator Pro had an update about a month ago to 1.9.0 but you have to install it yourself. I’m not sure whether Apple pushed and update that broke it. I didn’t test until you brought it up on this forum. I am checking into it further.
Maybe a recent Apple Software update broke this. Maybe I should try and set up MT Pro again for accessibility on the new version of Mac OS and try again? @bome-4964 said it was working a few days ago. I assume he is on MT Pro 1.9.0
Thanks. This is recorded as a bug and I hope we can fix it soon and report here. Meanwhile, any other findings are welcome!
One idea is to write AppleScript code into the Project Properties’ AppleScript section (as individual handlers), and then merely call those handlers from the individual outgoing AppleScript actions.
Hello Florian.
I would like to try your workaround in the mean time. Do you have an example or a skeleton code I could use as a starting point? I’m not sure how handlers work, I’m just a script kiddie.
