I try to switch preset together with the topmost window on screen. So that BMT switches settings when hopping between Cubase, ProTools and Adobe Premiere.
I see that some global variables can be set via AppleScript and can be misused for preset selection. Is this possible with WindowsPoweShell too?
a) How can I achieve an application specific preset selection as e.g. StreamDeck XL can.
b) How could I write an AppleScript or PowerShell "daemon" that watchdogs the topmost windows and switches global BMT parameters to select a preset.
Anny help appreciated
