Hello and a Happy New Year to everyone!
Using Midi Translator Pro with Arturia’s Keylab MK2.
I’m succesfully passing midi CCs and translate them using the software. However, At the same time, no notes are coming out of the keyboard! In order to have them play, I have to use Midi Thru from Bome to Arturia.
This thing is not happening when I use my Komplete Kontrol MK2, so here’s my question:
When using the translator, ALL events coming from the keyboard are supposed to be processed there? Or if I don’t have a rule for a control (e.g. a note key) this event should pass to my DAW and not be shallowed?
Here are my settings:
Inside Midi Translator Pro I have,
MIDI Input: Arturia Keylab 1 (Keylab 2 is reserved for Arturia’s commands)
MIDI Output: BOME MIDI Translator 1 Virtual out
In Cubase I have set Midi Input for each track to ALL Midi Inputs.
Any help will be really appreciated, thank you!
